you have to convert PDF to DXF and then import DXF using Eagle power tool,
one more method is to converte PDF to BMP( bitmap file ) and use Eagle Bitmap import ULP to import the same .
i will warn you that depending on the Pixel size the Size of the import may not be correct, use the scaling option in the ULP to match the actual layout size in the PDf document using trial and error method.
