[PIC] Convert "Int" to "string" and transmit using uart
helmi_mjd
Hi! I have one question regarding converting integer to string and transmit the data through uart as given in the code. The output are:1,2,3 instead of 1000,2000,3000. Where am I doing wrong?
#include "Compiler.h"
#include "delay.h"
#include "system.h"
#include "uart.h"
//DEVICE CONFIGURATION
_FOSC(CSW_FSCM_OFF & XT_PLL8);
//Watchdog Timer = Off.
_FWDT(WDT_OFF);
//Brown Out Reset = Off. POR Timer Value = 64ms.
//Master Clear = Enabled.
_FBORPOR(PBOR_OFF & PWRT_64 & MCLR_EN);
// Code Protection = On.
_FGS(CODE_PROT_OFF);
//MAIN FUNCTION
int main()
	//Clear all ports.
	LATA = 0; LATB = 0;
	LATC = 0; LATD = 0;
	LATF = 0;
	//Initialize port/pin as Output
	TRISA = 0; TRISB = 0;
	TRISC = 0; TRISD = 0;
	TRISF = 0;
	uart2_initialize();
	while(1){
		char string[4];
		int data[3] = {1000,2000,3000};
		itoa(&string[0],data[0],10);
		itoa(&string[1],data[1],10);
		itoa(&string[2],data[2],10);;
		string[3] = '\0';
		uart2_putstr(string);
		delay_ms(100);
void uart2_initialize(void)
   // Set the Baud Rate.
   U2BRG = 129;                        // ((Fosc/4)/(16 * Baud rate)) - 1
                                    // 129 = 9600bps baudrate for 10MHz crystal with 8xPLL
                                    // 20 = 57600bps baudrate for 10MHz crystal with 8xPLL
                                    // 10 = 115200bps baudrate for 10MHz crystal with 8xPLL
   U2STAbits.URXISEL = 0;                   // Interrupt flag bit is set for every character received.
   IPC6bits.U2RXIP   = 5;                   // UART2 Receive Interrupt Priority = 4.
   U2STAbits.OERR    = 0;                    // Clear the Receive Overflow Flag.
   IFS1bits.U2RXIF   = 0;                   // Clear the UART2 Receive Interrupt flag.
   IEC1bits.U2RXIE   = 0;                   // Disable UART2 Receive Interrupt.
   U2MODEbits.UARTEN = 1;                  // Enable UART2.
   U2STAbits.UTXEN = 1;                       // Enable UART2 Transmit.
void uart2_putstr(const char* csz_string)
   // Loop until the end of string.
   while (*csz_string != '\0') {
      uart2_transmit(*csz_string);
      // Point to next character.
      csz_string++;
void uart2_transmit(unsigned char uc_data)
   // Wait until the transmit buffer is ready for new data.
   while (U2STAbits.UTXBF == 1);
   // Transmit the data.
   U2TXREG = uc_data;
How do you want to put three 4 digit numbers into a string that has room for three characters?
itoa() is also writing "out of bounds" (behind the end of string[4]), possibly causing all kinds of unexpected. processor action.
This could e.g. work, but it's sending the numbers without any separator "100020003000"
Consider what you exactly want to achieve.
  char string[5];
   itoa(string,data[0]);
   itoa(string,data[1]);
   itoa(string,data[2]);
