[PIC] Convert ADC reading to DECIMAL numbers
kasamiko
Full Member level 3
Philippines
I'm simulating this circuit of battery charger in Proteus and wondering how to convert the result into decimal numbers. Like 14.42 V instead of 14420 mV.
PIC Simulator IDE code:
'PROGRAM TO CHARGE LEAD ACID BATTERIES WITH SOLAR PANEL
'USES PIC 16F877 AT 4 MHZ
'AUTHOR SANTHOSH JAYARAJAN
'NOTES:
'RA2=SOLAR CELL VOLTAGE
'RA1=BATTERY CHARGE CURRENT IB
'RB0-RB7:LCD DATA LINES
'RC0=PWM OUTPUT FOR CHARGER
'RD1:LCD R/S
'RD2:LCD R/W
'RD3:LCD-E
'RD4:SPARE
'RD6:SPARE
'VARIABLE DECLARATION FOR LCD MODULE
Define LCD_BITS = 8
Define LCD_DREG = PORTB
Define LCD_DBIT = 0
Define LCD_RSREG = PORTD
Define LCD_RSBIT = 1
Define LCD_EREG = PORTD
Define LCD_EBIT = 3
Define LCD_RWREG = PORTD
Define LCD_RWBIT = 2
Define ADC_SAMPLEUS = 100
Define LCD_LINES = 2
Define LCD_CHARS = 16
'for simulation only
Define LCD_COMMANDUS = 5000  'delay after LCDCMDOUT, default value is 5000
Define LCD_DATAUS = 100  'delay after LCDOUT, default value is 100
Define LCD_INITMS = 20
'SETTING THE TRISA,TRISB AND ADCON1 REGISTERS
'ALL A PINS ARE INPUTS AND 3 E PORTS AS INPUTS
TRISA = %00110111
ADCON1 = %00000000
TRISE = %00000111
ADCON0 = 0x80
TRISD = %11000000
TRISB = %00000000
INTCON = %10100000
OPTION_REG = %00000111
'VARIABLE DECLARTION
'FOR BATTERY VOLTAGE MEASUREMENT
Dim batt_curr As Word
Dim batt_curr_count As Byte
Symbol chg_on = PORTA.3
Dim boost_on As Bit
Dim trickle_on As Bit
Dim was_boost As Bit
Dim was_trickle As Bit
Dim trickle_time_count As Word
'FOR BATTERY and SOLAR VOLTAGE
Dim batt_volt_raw As Word
Dim batt_volt As Word
Dim solar_volt_raw As Word
Dim solar_volt As Word
'FOR BATTERY CURRENT
Dim batt_curr_raw As Word
Dim batt_cur As Word
Dim batt_curr_data(5) As Word
Dim set_curr As Word
'SOLAR CELL MINIMUM  VALUES
Dim batt_min_volt As Word
Dim solar_min_volt As Word
'POWER AND ENERGY CALCULATION
Dim power As Word
Dim energy As Word
Dim energy_aux As Word
Dim power_act As Word
'FOR INTERRUPT
Dim int_count As Byte
Dim en_count As Word
'MAIN LOGO AND DISPLAY INITIALISE
Lcdinit 0
WaitMs 10
Lcdcmdout LcdClear
Lcdcmdout LcdLine1Home
Lcdout "Solar Charge 1.0"
Lcdcmdout LcdLine2Home
Lcdout "SOLAR_CHARGE.hex"
WaitMs 2000
' FOR ENERGY CALCULATIONS
Dim en_unit As Byte
Dim en_ten As Byte
Dim en_hun As Byte
Dim en_thou As Byte
Dim en_total As Word
Dim en_unitc As Byte
Dim en_tenc As Byte
Dim en_hunc As Byte
Dim en_thouc As Byte
Dim en_totalc As Word
'START THE MAIN PROGRAM
solar_min_volt = 12600
batt_min_volt = 12100
energy = 0
'CLEAR SCREEN
Lcdcmdout LcdClear
Lcdcmdout LcdHome
'START MAIN PROGRAM
start:
Disable
Read 0, en_thou
Read 1, en_hun
Read 2, en_ten
Read 3, en_unit
Enable
en_total = en_thou * 1000 + en_hun * 100 + en_ten * 10 + en_unit
Gosub chk_solar_volt
Gosub chk_batt_volt
	If solar_volt > solar_min_volt Then
trickle_time_count = trickle_time_count + 1
If batt_volt < batt_min_volt Then
boost_on = 1
trickle_on = 0
Endif
If batt_volt >= batt_min_volt Then
boost_on = 0
trickle_on = 1
Endif
If boost_on = 1 Then
chg_on = 1
Endif
If trickle_on = 1 Then
	If trickle_time_count <= 2 Then
	chg_on = 1
	Endif
	If trickle_time_count > 2 Then
	chg_on = 0
	Endif
	If trickle_time_count >= 4 Then
	trickle_time_count = 0
	Endif
Endif
WaitMs 1000
Gosub chk_batt_curr
Lcdcmdout LcdClear
Lcdcmdout LcdHome
Lcdcmdout LcdLine1Clear
Lcdout "B.Volts:", #batt_volt, " mV"
Lcdcmdout LcdLine2Clear
Lcdout "C.Curr:", #batt_curr, " mA"
WaitMs 2000
Lcdout "Energy(Wh)", #en_total,
Lcdout "Power: ", #power, " mW"
WaitMs 2000
Lcdout "Solar V:", #solar_volt, " mV"
Lcdout "B.Volt: ", #batt_volt, " mV"
WaitMs 2000
Lcdout "Boost Chg: ON"
Else
Lcdout "Boost Chg: OFF"
Endif
Lcdout "Trickle Chg: ON"
Else
Lcdout "Trickle Chg: OFF"
Endif
WaitMs 1000
	Else
Lcdout "Low Solar Volts"
Lcdout "Waiting..",
WaitMs 2000
WaitMs 2000
WaitMs 2000
	Endif
Goto start
End
'CHECK SOLAR CELL VOLTAGE
'return batt_volt in mV
chk_solar_volt:
was_boost = 1
Else
was_boost = 0
Endif
was_trickle = 1
Else
was_trickle = 0
Endif
chg_on = 0
WaitMs 50
Adcin 2, solar_volt_raw
solar_volt = solar_volt_raw * 20
If was_boost = 1 Then
boost_on = 1
Else
boost_on = 0
Endif
If was_trickle = 1 Then
trickle_on = 1
Else
trickle_on = 0
Endif
was_boost = 0
was_trickle = 0
Return
'CHECK BATTERY CURRENT
'return batt_curr in ma
chk_batt_curr:
For batt_curr_count = 0 To 4
Adcin 1, batt_curr_data(batt_curr_count)
WaitMs 10
Next batt_curr_count
batt_curr_raw = (batt_curr_data(0) + batt_curr_data(1) + batt_curr_data(2) + batt_curr_data(3) + batt_curr_data(4)) / 5
batt_curr = batt_curr_raw
Return
'CHECK BATTERY VOLTAGE
chk_batt_volt:
was_boost = 1
Else
was_boost = 0
Endif
was_trickle = 1
Else
was_trickle = 0
Endif
chg_on = 0
WaitMs 50
Adcin 0, batt_volt_raw
batt_volt = batt_volt_raw * 20
boost_on = 1
Else
boost_on = 0
Endif
trickle_on = 1
Else
trickle_on = 0
Endif
was_boost = 0
was_trickle = 0
Return
On Interrupt
Save System
en_count = en_count + 1
int_count = int_count + 1
'1 SEC INTERRUPT
If int_count = 15 Then
int_count = 0
power = (batt_volt / 1000) * (batt_curr)
energy_aux = energy_aux + power
'ENERGY IN WS
If energy_aux >= 1000 Then
energy = energy + 1
energy_aux = 0
Endif
'ENERGY IN WH
If energy >= 3600 Then
en_totalc = en_totalc + 1
energy = 0
Endif
If en_totalc >= 9999 Then
en_totalc = 0
Endif
Endif
'1/2 HR INTERRUPT
If en_count = 27000 Then
en_count = 0
en_unitc = en_totalc Mod 10
en_tenc = (en_totalc / 10) Mod 10
en_hunc = (en_totalc / 100) Mod 10
en_thouc = en_totalc / 1000
Write 0, en_thouc
Write 1, en_hunc
Write 2, en_tenc
Write 3, en_unitc
Endif
INTCON.T0IF = 0
Resume
One of the logic which i learnt from net are following .
14420 millivolt separate each digit by modular division .
remove last zero digit by dividing it by 10 .
then the result is 1442 milli volt
then separate each digit as following
4th digit = 1442 % 10 = 2.
3rd digit = 1442 /10 = 4
@nd Digit = (1442/100)%10 =4
1st digit = (1442/1000)%10 =1
Then display each digit
i made an project in which these logic are used ,but which is AVR https://circuits-collection.blogspot.in/2015/12/microcontroller-based-ammeter-and.html
