convert 4-20mA to 0-5V using op-amp
ecaits
Member level 4
Member level 4
Dear Sir,
I want to convert 4-20mA to 0-5V using op-amp. Can anyone have circuit diagram for that?
Nirav
Dear Sir,
Nirav
search with google by current to voltage converter
and you should use instrumentation amplifier.could be a little bit expensive
more detail "http://www.ti.com/lit/an/snoa423b/snoa423b.pdf"
hope it helps
zeyad
Use a resistor to convert mA into volts, then use a non-inverting opamp with appropriate gain & level shifting to get your 0-5v.
E.g. using a 330ohm resistor in series, you will get 330 x 0.004 = 1.32v, and 330 x 0.020 = 6.6v. This is a range of 5.28volts. So you need a gain of 5/ 5.28 = 0.947
Also you need to simultaneously level-shift the 1.32v down to 0, so you need to apply a 1.32 x 5/ 5.28 = 1.394v on the inverting input (if it has the same gain). Otherwise just apply an offset voltage thru' a pot to get your desired output.
Here's a **broken link removed**with circuits and explanations
Reactions: rmanze
    rmanze
