library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity gcd is
port (
clk : in std_logic;
reset : in std_logic;
start : in std_logic;
a : in std_logic_vector(15 downto 0);
b : in std_logic_vector(15 downto 0);
outp : out std_logic_vector(15 downto 0);
done : out std_logic;
ready : out std_logic
end gcd;
architecture fsmd of gcd is
type state_type is (S_ENTRY, S_EXIT, S_001_001, S_001_002, S_001_003, S_001_004, S_002_001, S_003_001, S_004_001, S_004_002, S_004_003, S_005_001, S_005_002, S_005_003, S_006_001, S_006_002, S_007_001, S_007_002, S_008_001, S_008_002, S_008_003, S_009_001, S_009_002, S_009_003, S_010_001);
signal current_state, next_state: state_type;
signal D_1966_1_reg : std_logic_vector(31 downto 0);
signal D_1966_1_eval : std_logic_vector(31 downto 0);
signal result_11_next : std_logic_vector(15 downto 0);
signal result_11_reg : std_logic_vector(15 downto 0);
signal result_11_eval : std_logic_vector(15 downto 0);
signal x_1_next : std_logic_vector(15 downto 0);
signal x_1_reg : std_logic_vector(15 downto 0);
signal x_1_eval : std_logic_vector(15 downto 0);
signal x_7_next : std_logic_vector(15 downto 0);
signal x_7_reg : std_logic_vector(15 downto 0);
signal x_7_eval : std_logic_vector(15 downto 0);
signal y_7_next : std_logic_vector(15 downto 0);
signal y_7_reg : std_logic_vector(15 downto 0);
signal y_7_eval : std_logic_vector(15 downto 0);
signal x_8_next : std_logic_vector(15 downto 0);
signal x_8_reg : std_logic_vector(15 downto 0);
signal x_8_eval : std_logic_vector(15 downto 0);
signal y_8_next : std_logic_vector(15 downto 0);
signal y_8_reg : std_logic_vector(15 downto 0);
signal y_8_eval : std_logic_vector(15 downto 0);
signal y_1_next : std_logic_vector(15 downto 0);
signal y_1_reg : std_logic_vector(15 downto 0);
signal y_1_eval : std_logic_vector(15 downto 0);
signal result_9_next : std_logic_vector(15 downto 0);
signal result_9_reg : std_logic_vector(15 downto 0);
signal result_9_eval : std_logic_vector(15 downto 0);
signal result_12_next : std_logic_vector(15 downto 0);
signal result_12_reg : std_logic_vector(15 downto 0);
signal result_12_eval : std_logic_vector(15 downto 0);
signal D_1964_1_next : std_logic_vector(31 downto 0);
signal D_1964_1_reg : std_logic_vector(31 downto 0);
signal D_1964_1_eval : std_logic_vector(31 downto 0);
signal D_1965_1_next : std_logic_vector(31 downto 0);
signal D_1965_1_reg : std_logic_vector(31 downto 0);
signal D_1965_1_eval : std_logic_vector(31 downto 0);
signal x_5_next : std_logic_vector(15 downto 0);
signal x_5_reg : std_logic_vector(15 downto 0);
signal x_5_eval : std_logic_vector(15 downto 0);
signal y_6_next : std_logic_vector(15 downto 0);
signal y_6_reg : std_logic_vector(15 downto 0);
signal y_6_eval : std_logic_vector(15 downto 0);
signal outp_next : std_logic_vector(15 downto 0);
signal outp_reg : std_logic_vector(15 downto 0);
signal outp_eval : std_logic_vector(15 downto 0);
constant CNST_0 : std_logic_vector(31 downto 0) := "00000000000000000000000000000000";
begin
process(clk.reset)
begin
begin (clk, reset)
if (reset = '1') then
current_state <= S_ENTRY;
D_1966_1_reg <= (others => '0');
result_11_reg <= (others => '0');
x_1_reg <= (others => '0');
x_7_reg <= (others => '0');
y_7_reg <= (others => '0');
x_8_reg <= (others => '0');
y_8_reg <= (others => '0');
y_1_reg <= (others => '0');
result_9_reg <= (others => '0');
result_12_reg <= (others => '0');
D_1964_1_reg <= (others => '0');
D_1965_1_reg <= (others => '0');
x_5_reg <= (others => '0');
y_6_reg <= (others => '0');
outp_reg <= (others => '0');
elsif (clk = '1' and clk'EVENT) then
current_state <= next_state;
-- D_1966_1_reg <= D_1966_1_next;
D_1966_1_reg <= aa;
result_11_reg <= result_11_next;
x_1_reg <= x_1_next;
x_7_reg <= x_7_next;
y_7_reg <= y_7_next;
x_8_reg <= x_8_next;
y_8_reg <= y_8_next;
y_1_reg <= y_1_next;
result_9_reg <= result_9_next;
result_12_reg <= result_12_next;
D_1964_1_reg <= D_1964_1_next;
D_1965_1_reg <= D_1965_1_next;
x_5_reg <= x_5_next;
y_6_reg <= y_6_next;
outp_reg <= outp_next;
end if;
end process;
-- next state and output logic
process (current_state, start,
a,
b,
outp_reg,
D_1966_1_reg, D_1966_1_next,
result_11_reg, result_11_next,
x_1_reg, x_1_next,
x_7_reg, x_7_next,
y_7_reg, y_7_next,
x_8_reg, x_8_next,
y_8_reg, y_8_next,
y_1_reg, y_1_next,
result_9_reg, result_9_next,
result_12_reg, result_12_next,
D_1964_1_reg, D_1964_1_next,
D_1965_1_reg, D_1965_1_next,
x_5_reg, x_5_next,
y_6_reg, y_6_next
begin
done <= '0';
ready <= '0';
D_1966_1_next <= D_1966_1_reg;
result_11_next <= result_11_reg;
x_1_next <= x_1_reg;
x_7_next <= x_7_reg;
y_7_next <= y_7_reg;
x_8_next <= x_8_reg;
y_8_next <= y_8_reg;
y_1_next <= y_1_reg;
result_9_next <= result_9_reg;
result_12_next <= result_12_reg;
D_1964_1_next <= D_1964_1_reg;
D_1965_1_next <= D_1965_1_reg;
x_5_next <= x_5_reg;
y_6_next <= y_6_reg;
outp_next <= outp_reg;
case current_state is
when S_ENTRY =>
ready <= '1';
if (start = '1') then
next_state <= S_001_001;
else
next_state <= S_ENTRY;
end if;
when S_001_001 =>
x_1_next <= a(15 downto 0);
y_1_next <= b(15 downto 0);
next_state <= S_001_002;
when S_001_002 =>
x_8_next <= x_1_reg(15 downto 0);
y_8_next <= y_1_reg(15 downto 0);
if (x_1_reg /= CNST_0(15 downto 0)) then
D_1964_1_next <= "00000000000000000000000000000001";
else
D_1964_1_next <= (others => '0');
end if;
if (y_1_reg /= CNST_0(15 downto 0)) then
D_1965_1_next <= "00000000000000000000000000000001";
else
D_1965_1_next <= (others => '0');
end if;
next_state <= S_001_003;
when S_001_003 =>
D_1966_1_next <= D_1964_1_reg and D_1965_1_reg(31 downto 0);
next_state <= S_001_004;
when S_001_004 =>
if (D_1966_1_reg /= CNST_0(15 downto 0)) then
next_state <= S_002_001;
else
next_state <= S_009_001;
end if;
when S_002_001 =>
next_state <= S_007_001;
when S_003_001 =>
if (x_8_reg >= y_8_reg(15 downto 0)) then
next_state <= S_004_001;
else
next_state <= S_005_001;
end if;
when S_004_001 =>
x_5_next <= std_logic_vector(unsigned(x_8_reg) - unsigned(y_8_reg(15 downto 0)));
next_state <= S_004_002;
when S_004_002 =>
x_7_next <= x_5_reg(15 downto 0);
next_state <= S_004_003;
when S_004_003 =>
next_state <= S_006_001;
when S_005_001 =>
y_6_next <= std_logic_vector(unsigned(y_8_reg) - unsigned(x_8_reg(15 downto 0)));
next_state <= S_005_002;
when S_005_002 =>
y_7_next <= y_6_reg(15 downto 0);
next_state <= S_005_003;
when S_005_003 =>
when S_006_001 =>
x_8_next <= x_7_reg(15 downto 0);
y_8_next <= y_7_reg(15 downto 0);
next_state <= S_006_002;
when S_006_002 =>
when S_007_001 =>
x_7_next <= x_8_reg(15 downto 0);
y_7_next <= y_8_reg(15 downto 0);
next_state <= S_007_002;
when S_007_002 =>
if (x_8_reg /= y_8_reg(15 downto 0)) then
next_state <= S_003_001;
else
next_state <= S_008_001;
end if;
when S_008_001 =>
result_9_next <= x_8_reg(15 downto 0);
next_state <= S_008_002;
when S_008_002 =>
result_12_next <= result_9_reg(15 downto 0);
next_state <= S_008_003;
when S_008_003 =>
next_state <= S_010_001;
when S_009_001 =>
result_11_next <= CNST_0(15 downto 0);
next_state <= S_009_002;
when S_009_002 =>
result_12_next <= result_11_reg(15 downto 0);
next_state <= S_009_003;
when S_009_003 =>
when S_010_001 =>
outp_next <= result_12_reg(15 downto 0);
next_state <= S_EXIT;
when S_EXIT =>
done <= '1';
when others =>
end case;
end process;
outp <= outp_reg;
end fsmd;
