how to send 16 bit data as a 8 bit data in uart
that is i use uart 4 my project it accept uart 8 bit mode
if anyone none means help me
thank u in advance
you will have to split hte data and then send... if data_16 is ur actual data to be transmitted, then send the LSB 8 bits of data_16 first, then take the MSB 8bits.. you can register the 16 bit data and then use the delayed version of it when ur sending the MSB 8 bits..
