Tiiu
Junior Member level 1
When I run a simulation with hspice,it can't reach convergence.
In the .lis file,the hspice diagnostic provided some nodes whose tol value are bigger than 1( the actual tol values are about 500).
And I found those nodes are the power supply voltage sources and the nodes where there are input waves.
how should I deal with them?
Btw, I had added 1 ohm resistor between the power supply voltage sources and gnd
