skywalker898
- Joined
- Jan 31, 2012
- Messages
- 32
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Madison, WI
- Activity points
- 1,622
Hi, I have multiple pieces of equipment that need to be able to be turned off using an emergency off button ESTOP. Because the total current draw is high for all equipment, I need multiple breakers, and consequently multiple contactors. The easiest way to turn off all these contactors simultaneously seems to be to just run the ESTOP control line through all the contactors' control lines. I am wondering if this seems like an appropriate solution?
I've attached a picture that shows two contactors, with their control lines in parallel, but with the ESTOP able to cut current to both. Is this how one would normally use an ESTOP to control multiple breakers?
Thanks,
Brandon
Thanks,
Brandon
