controlling motor with the right current
sevi29
Newbie level 2
Newbie level 2
i had this circuit for controlling 2 wiper motors using a motor driver - L293D and relay
i used l293d to control the direction of motor but it only provides small amount of current, so it can only drive small motors like DC. when i tried to control the wiper motor, it does worked but can't make it rotate. i was thinking that it's because i'm using a regulated power supply that gives less current.
to test if my wiper motor is really working, i connected it directly to a 12 v, 3 amps transformer, and it did work the way it should, so i assume that the current really affects the controlling of motor.
so i tried putting a relay. as far as i can understand, it needs small amount of current to be triggered but its output gives a bigger current.
when i tried it, i've got the same result when i just used l293d.
please help me fixed this problem.
here's my circuit:
here's also the circuit of the regulated power supply that i used:
