Ching
Newbie level 5
- Joined
- Jan 17, 2007
- Messages
- 10
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,385
pr4101
I want to make a circuit in order to control the brightness of a power LED(5W). I brought a LED driver (PR4101) and its demo broad already. And my circuit is operated at 12Vac (or may be 24Vac) input.
In the PR4101 datasheet (P.10), there is an explanation of "typical application with 12Vac supply and phase cut dimmers". However, I am not understand what is the use of the pin "PWM" as it stated that this pin can control the brightness of LED in the datasheet. As shown in P.10, only "VDI" is connected, but "PWM" is not connected to anything else. Is the brightness of LED really can be controlled even if the PWM pin is not connected? and its brightness is depend on the turn-off/on portion of the incoming voltage only? Actually, I am not sure what the input signal should be so that I can dim the LED. Am I right to think that the brightness can be controlled by the turn-on/off protion of the input signal as shown in P.10 of the datasheet? Is there someone can give me the schematic diagram to show me how to set up the correct input signal for the diagram shown in P.10 or to PR4101 demo board (P.18 ) so that I can control the LED's brightness? Thank you.
PR4101 datasheet:
PR4101 datasheet:
