Control motor using arduino PID and processing
satya82
Newbie level 6
Newbie level 6
Hi Forum
I had done PID code using arduino and hardware with feedback opto sensor.I just dont understand why my output shows 0 value or constant value 255.Can you advice please thank you.
can you provide any more details? What your Opto reads 0? is it going to a analog input?
Here is my arduino code.The Ao pin connect to the opto sensor and pwm pin 13 connect to output dc motor.
#include <PID_v1.h>
double Setpoint, Input, Output;
PID myPID(&Input, &Output, &Setpoint,2,5,1, DIRECT);
int inputPin=0, outputPin=3;
unsigned long serialTime;
//LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
#include <SoftwareSerial.h>
int ActPos = A1;    // select the input pin for feedback signal
int DesPos = A0;    // select the input pin for control signal
byte PWMOutput;
long Error[10];
long Accumulator;
long PID;
int PTerm;
int ITerm;
int DTerm;
byte Divider;
volatile int rpmcount = 0;//see http://arduino.cc/en/Reference/Volatile
int rpm = 0;
unsigned long lastmillis = 0;
int enablePin = 11;
int in1Pin = 10;
int in2Pin = 9;
int switchPin = 8;
int potPin = 1;
void setup()
  Serial.begin(9600);
pinMode(in1Pin, OUTPUT);
pinMode(in2Pin, OUTPUT);
pinMode(enablePin, OUTPUT);
pinMode(switchPin, INPUT_PULLUP);
//lcd.begin(16, 2);
//lcd.print("rpm!");
Serial.begin(9600);
Input = analogRead(inputPin);
Setpoint = 100;
attachInterrupt(0, rpm_fan, FALLING);//interrupt cero (0) is on pin two(2).
 myPID.SetMode(AUTOMATIC);
void GetError(void)
  byte i = 0;
  word ActualPosition = analogRead(ActPos);
   word DesiredPosition = analogRead(DesPos);
    for(i=0;i<10;i++)
    Error[i+1] = Error[i];
    Error[0] = (long)DesiredPosition-(long)ActualPosition;
void CalculatePID(void)
   PTerm = 2000;
  ITerm = 25;
  DTerm = 0;
  Divider = 10;
// Calculate the PID
  PID = Error[0]*PTerm;     // start with proportional gain
  Accumulator += Error[0];  // accumulator is sum of errors
  PID += ITerm*Accumulator; // add integral gain and error accumulation
  PID += DTerm*(Error[0]-Error[9]); // differential gain comes next
  PID = PID>>Divider; // scale PID down with divider
   if(PID>=127)
    PID = 127;
  if(PID<=-126)
    PID = -126;
 PWMOutput = PID + 127;
union {                // This Data structure lets
  byte asBytes[24];    // us take the byte array
  float asFloat[6];    // sent from processing and
}                      // easily convert it to a
foo;                   // float array
void SerialReceive()
  // read the bytes sent from Processing
  int index=0;
  byte Auto_Man = -1;
  byte Direct_Reverse = -1;
  while(Serial.available()&&index<26)
    if(index==0) Auto_Man = Serial.read();
    else if(index==1) Direct_Reverse = Serial.read();
    else foo.asBytes[index-2] = Serial.read();
    index++;
  // if the information we got was in the correct format,
  // read it into the system
  //if(index==26  && (Auto_Man==0 || Auto_Man==1)&& (Direct_Reverse==0 || Direct_Reverse==1))
   // Setpoint=double(foo.asFloat[0]);
    //Input=double(foo.asFloat[1]);       // * the user has the ability to send the
                                          //   value of "Input"  in most cases (as
                                          //   in this one) this is not needed.
   // if(Auto_Man==0)                       // * only change the output if we are in
   // {                                     //   manual mode.  otherwise we'll get an
   //   Output=double(foo.asFloat[2]);      //   output blip, then the controller will
   // /}                                     //   overwrite.
void loop()
  myPID.Compute();
  analogWrite(outputPin,Output);
int speed = analogRead(potPin) / 4;
myPID.Compute();
boolean reverse = digitalRead(switchPin);
setMotor(speed, reverse);
 if (millis() - lastmillis >= 1000){  //Uptade every one second, this will be equal to reading frecuency (Hz).
 detachInterrupt(0);    //Disable interrupt when calculating
 rpm = rpmcount * 60;  // Convert frecuency to RPM, note: this works for one interruption per full rotation. For two interrups per full rotation use rpmcount * 30.
 Serial.print("RPM =\t"); //print the word "RPM" and tab.
 Serial.print(rpm); // print the rpm value.
 Serial.print("\t Hz=\t"); //print the word "Hz".
 Serial.println(rpmcount); //print revolutions per second or Hz. And print new line or enter.
 rpmcount = 0; // Restart the RPM counter
 lastmillis = millis(); // Uptade lasmillis
 attachInterrupt(0, rpm_fan, FALLING); //enable interrupt
 if(millis()>serialTime)
    SerialReceive();
    SerialSend();
    serialTime+=500;
void SerialSend()
  Serial.print("PID ");
  Serial.print(Setpoint);
  Serial.print(" ");
  Serial.print(Input);
  Serial.print(" ");
  Serial.print(Output);
  Serial.print(" ");
  Serial.print(myPID.GetKp());
  Serial.print(" ");
  Serial.print(myPID.GetKi());
  Serial.print(" ");
  Serial.print(myPID.GetKd());
  Serial.print(" ");
  if(myPID.GetMode()==AUTOMATIC) Serial.print("Automatic");
  else Serial.print("Manual");
  Serial.print(" ");
  if(myPID.GetDirection()==DIRECT) Serial.println("Direct");
  else Serial.println("Reverse");
void setMotor(int speed, boolean reverse)
analogWrite(enablePin, speed);
digitalWrite(in1Pin, ! reverse);
digitalWrite(in2Pin, reverse);
void rpm_fan(){ // this code will be executed every time the interrupt 0 (pin2) gets low.
  rpmcount++;
Dear Forum
Need your help regarding PID code using arduino and hardware with feedback opto sensor.I just dont understand why my output shows 0 value or constant value 255.Can you advice please thank you.
I already attach code .Hopefully you can help me please.Thank you.
#include <PID_v1.h>
const double Kp=10;
const double Ki=0;
const double Kd=0;
PID myPID(&Input, & Output, &Setpoint, Kp, Ki, Kd, DIRECT);
int rpm = 0;
int enablePin = 11;
int in1Pin = 10;
int in2Pin = 9;
int switchPin = 8;
int potPin = 1;
void setup()
  Serial.begin(9600);
//lcd.begin(16, 2);
Serial.begin(9600);
Input = analogRead(0);
Setpoint = 100;
//union {                // This Data structure lets
  //byte asBytes[24];    // us take the byte array
  //float asFloat[6];    // sent from processing and
//}                      // easily convert it to a
//foo;                   // float array
   //read the bytes sent from Processing
  int index=0;
  byte Auto_Man = -1;
    //else foo.asBytes[index-2] = Serial.read();
    index++;
   // /}                                     //   overwrite.
void loop()
  myPID.Compute();
  analogWrite(3,Output);
myPID.Compute();
    SerialReceive();
    SerialSend();
   serialTime+=500;
void SerialSend()
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(" ");
  rpmcount++;
