Contact Resistance Calculation
dream_taker
Junior Member level 1
sheet contact resistance calculation
Can anyone tell me how to find the contact resistance for a process. If I draw a huge transistor of w/l with m=x fingers, then how to go abt it.
Tks
you can find it in process techfile
good luck
I think yuo can find in founday design manual. Usually it is in the order of 5~10 ohms per contact.
Yibin.
About contact resistance calculation,it should be included in the foundry's design manual.Usually contact resistance is 0.5 square resistance. The square resitance's value is the resistor that is designed by you.
For RF operation, each contact behaves in a more complex manner. It has to be modeled as an inductance with some capacitance and resistance. The DC resistance is as pointed out above is around 4 ohms per contact. That's why having multiple contacts reduces resistance and improves current flow, and reduces capacitance as well, which may become a high reactance at a certain frequency. Xc=1/(wC)
Check your RF models for a detailed discussion as it relates to the technology that you are using and follow any guidelines there.
