I want to know how to add constraint to xilinx spartan2e product?
what is the exact meaning of the constraint?
what is the main benefit after we add some certain constraint to FPGA?
thank again!
I also use ISE 6.1 so I think constrain means that we fix the pin of FPGA for my design. If you do not make constrain file (*.ucf) the ISE 6.1 software can automatic to define input pin and out put pin for your design.
You can always edit the UCF-file by opening it in an editor (notepad). In former releases of ISE WebPack v4 & v5 the constraint editor (GUI) had some bugs and strange behaviour. So I prefered to edit the UCF-file manually and everything worked fine. I don't know if this was fixed in v6.
