sherry151
Newbie level 1
I have a combinational path that goes through a black box RAM. I am unable to find an accurate way to constrain this path. I do not have the .lib file for the RAM. I know the read latency of the RAM though. Conceptually this should be very simple as I just need to tell the tool that even though the connection from the address input to the address output of the RAM is not visible, there is in fact a connection and the delay for that connection is 'X ps' . Then the tool can easily optimize the logic on both sides of the RAM easily.
A second option, which I know how to do, would be to split up the clock cycle into, say, half on each side and use max_delay -to and max_delay -from constraints on the input and output side of the RAM respectively also taking into account the read latency.
Tool Used: Design Compiler
Thanks!
Thanks!
