Constant Voltage/Constant Current Circuit?
Baz1
Newbie level 3
constant current circuit
Anyone have any good CV/CC circuit designs used for charging a battery?
Thanks,
Baz1
constant current circuit design
IN THE NAME OF GOD
HI
FIRST YOU SHOULD SAY WHATH KID OF BATTERY DO YOU USE?
I MEAN 1.2V AA OR 9V OR 12V CAR BATTERY
BETTER SAY VOLTAGE AND CURRENT FOR APPROTIATE TRANSISTOR.
FOR 12V CAR BATTERY CHARGER
OTHERS
http://www.discovercircuits.com/B/batt-chrg1.htm
BEST REGRDS
voltage to current circuit
Hi Baz1,
have a look at some of the battery charger datasheet from Linear technology.
They provide the block digram for the same.
You could develop from their on.
constant current circuits
thanks to everyone for the resources, their helping.
The design is to charge a lead-acid 6 volt battery using a microprocessor for a intelligent charging system.
constant current constant voltage charger
"IN THE NAME OF GOD"
hi
tell me the current for charging
or
say the name of company and model for searching it's current.
best regards
constant voltage electrical circuit for charging
what is your source?
maybe u can try with dc-dc converter
in case of charging a battery
it is good to use half wave rectifier with a series resistor to limit the charging current
this configuration also tricle charge your battery, if your battery is fully charged
