Constant amplitude amplifier
sita
Member level 1
hi
is there any constant amplitude kind of amplifier? if so can you propose
thanks
sita
can anyone pls suggest a current amplifier circuitry?
also, is it possible to keep the amplify and keep the voltage of current amplifier constant?
what i am looking at now is an amplifier which can give 40 Vp-p signal
hi Audioguru: can you pls provide me details regarding the automatic level control circuitry?
regards,
sita
Sounds confused. What makes you think a current amplifier is required for your application? Why the "amplify" (the gain?)
shall be kept constant?
Google has links to thousands of automatic volume control circuits. This is the first one: https://electroschematics.com/479/automatic-volume-control/
You might not like it because its attack time for a loud signal is slow so it comes through blasting for a moment before this circuit attenuates it. Then if there are quiet sounds it takes a few seconds for the volume to increase.
hi
I was talking about an amplifier which can produce constant amplitude, irrespective of the input voltage amplitude
Somethinh like CURRENT AMPLIFIER. If anyone has any data/circuit on the same. can you pls help me to get some documents on the same?
in google, I am not able to correct;y find out current amplifier
regards,
Asvini[/i]
Your question is not very clear (at least for me).
1) You ask for an amp with constant voltage output. Ok, you need a variable gain amp plus an Automatic Gain Control to (AGC or ALC) to maintain your output constant. Audioguru showed an example
2) Then you said your amp should be something like a "current amp" but what do you mean?
