Connecting two SFP+ "male" connectors?
std_match
Sweden
I want to connect two SFP+ male connectors. One of them is an optical SFP+ module, so it must be powered.
It is possible to buy cables with SFP+ male connectors in both ends, so it should also be easy to connect two male connectors. The problem is that I can't find anything like that to buy.
It is not ethernet, so I can't use a normal switch that accept SFP+ modules.
I don't find an adapter of this kind at first sight, so may be you have to make your own mini PCB with two SFP+ connectors.
