plusmartin
Newbie level 5
Hi!
I want to charge a battery with two small generators that will spin on wind power.
At low speeds the voltage across the generators will not be high enough to surpass the 12V battery, therefore I want to connect the generators in series.
When the generators spin faster the voltage will be higher and each of them will be able to charge the battery by itself. I will connect them in parallel when this happens.
I designed a simple circuit, please give me your comments
