bharat bhushan
Triac is generally operated in Mode 1 & Mode3 modes of operation. And when we connect the gate from MT2 terminal of triac through a resistance (and maybe through optocoupler diac which works as a switch), as current flows in from MT2 to MT1 in say first half cycle of ac, and then in opposite direction in second half cycle, triac get automatically operated in mode 1 & mode 3. Its very much clear till here . But as it is an ac current which will flow in both direction alternatively , so I think it should not matter where the load is connected, on MT1 terminal or MT2 terminal. After all triac working as a switch which should be in series with the load. What else should be needed?
Yet generally in all circuits available on net , it is shown that load is connected with MT2 terminal ,whereas line in is connected on MT1 terminal.
One may say that , it is for hot line switching , so that when triac is switched off , load should not be connected with hot line, but same may be achieved by connecting hot line/phase at MT2 terminal , gate connected to MT2 through resistance and optocoupler (optionally) , and connecting load to MT1 at one side and neutral line at other side. In this way load will be at same potential as neutral or earth when triac will be off.
But still such circuit is rarely seen on net. I have tested this circuit, it works .
Is there any problem in this circuit? Please clarify .
Thanks
Thanks
