I have a circuit where I need a 12VDC current limited LED to light up when a voltage between 150 to 300VDC (2-4 A) turns on.
I have a 12VDC power source that I could use to power the LED, but I basically need a good way to control it. I thought about using a relay that supports voltages up to around 300VDC on the control signal and a low current on the switched signal but I can't seem to find any that matches.
Oh, and all of these things are external mounted devices.. No PCB components.
Does anyone have any good ideas on how to do this?
Thank you mister_rf. In an attempt to keep time and spent money to a minimum, I want to avoid developing my own PCB for just this cause. But you are right, I am looking for something like this, but I need it or something similar to this as a complete mechanical part.
Unfortunately it goes only up to 280VDC for the control signal, and the relay has a minimum current of 20mA which is just around what the LED uses. I could of course buy one and test if it works anyway, it probably would. But the fact that it only goes up to 280VDC makes it a bit tough to use.
Thank you for your answer BradtheRad Yes I can use the high voltage supply. I have actually used this solution earlier on a similar setup. I was hoping this time that I could avoid the high voltage at the LED, but if there is no better solution this will be the way to go.
The control signal is a current of 4mA @ 240V in. So all you need to do is add a resistor in series that drops the voltage from 300V to 240V @ 4mA. The resistor value would be 60V/4mA = 15kΩ. The maximum resistor dissipation is 60V * 4mA = 240mW so use a 1/2 or 1 watt resistor.
I'm not sure why they have a minimum load current but, if it's a problem, just add a resistor in parallel with the LED to increase the current slightly.
There are relays whose coils operate on mains AC voltage. They draw tiny current. I'm pretty sure one could handle DC. If you need to limit current then a resistor will do the job (as post #5 describes).
As for the switch, just about any of them should have no problem handling a load of 20 mA at 12V.
