Confusing various battery charging chemistry..
dsanthosh67
Member level 4
INDIA
I have a battery charging circuit with an ic of max712, It is capable to charge Nickel Metal hydride(NiMH) and Nickel Cadmium(Nicd) type of batteries. Shall I Connect Lithium Ion Battery with this charging Circuit?...I have a confusion because every charging ic will specifying supported type of battery. Basically CC/CV is the charging principle then why charging ic will not supporting all type of batteries.
Regards,
Santhoshkumar.
I think it depends on the charging rate, for example some are C/1, some C/3 (perhaps the MAX712 can't be configured for Li Ion charge rate?), and possibly other issues. I hope either of these documents is helpful:
  • Battery Charging snva557.pdf
  • panasonic_li-ion_charging_information.pdf
if you want to charge Li-Ion, then use a Li-Ion charger. The MAX712 is no Li-Ion charger.
Maxim has a lot Li-Ion charger ICs.
Klaus
Can i charge Lead Acid battery with this Charger IC MAX712?...
Regards,
Santhoshkumar..
It looks like no.
"Description
The MAX712/MAX713 fast-charge Nickel Metal Hydride (NiMH) and Nickel Cadmium (NiCd) batteries..."
"Key Features:
Fast-Charge NiMH or NiCd Batteries"
Maybe browsing the parametric search options will help to choose the right charger if you need one for lead acid or universal battery chemistries.
--> similar as post#3:
if you want to charge lead acid batteries, then use alead acid batteries charger. The MAX712 is no lead acid batteries charger.
Maxim has a lot lead acid batteries charger ICs.
Klaus
The gist of all this is that you should use a battery charger only for the type of battery it is designed for.
Each type of battery has its own requirements for proper charging, and trying to charge a different type of battery can result in battery failure or even an explosion and fire if it's a lithium-ion type.
