userx51
Junior Member level 2
In my keil program, during the run time I like in my code to check a value and come up with the following:
depending on a variable, var1 , bypass one of the settings[] in below.like if var1 = 1, the settings would be the first one and if var = 2,the settings would be the second one.
and also,
#define arrsz 10
if var = 2, arrsz for xbuf change to 20.
struct SS
int a,b,c,d;
static SS code settings[] =
{1,2,3,4},
{5,6,7,8}
{1,2,3,4},
{5,6,7,8},
{9,10,11,12}
and also,
#define arrsz 10
unsigned char xdata xbuf[arrsz];
