perchick
Newbie level 5
Hi
im writing a tic tac toe checker and i was wondering if i could get some help about conditions outside a process.
i just wanted to say that I've already wrote this code using a procedure but i wanted to learn how to do this with components
this is just the start of the code, when ill understand how do i work outside a process ill write the rest
the rules are: d_in is 2 bit vector who writes the board. "00" and "11" has no affect (they do but it's not relevant for now), "10" is o_win, "01" is x_win.
my code so far:
my problems with this are mentioned in the code
hope someone can explain how do i work outside a process
thanks in advance
my code so far:
library ieee;
use ieee.std_logic_1164.all;
use work.TicTacToe.all; ---package woth type state (x_win, o_win, no_win, idle)
entity FSM is
port ( d_in : in std_logic_vector (1 downto 0);
PS : in state;
NS : out state := idle);
end FSM;
architecture arch_FSM of FSM is
begin
process (PS, d_in)
begin
case PS is
when idle =>
--result <= "00";
if d_in = "01" then
NS <=x_win;
elsif d_in = "10" then
NS <=o_win;
else
NS <= idle;
end if;
when x_win =>
--\result <= "01";
if d_in = "10" then
NS <= no_win;
else
NS <= x_win ;
end if;
when o_win =>
--result <= "10";
if d_in = "01" then
NS <= no_win;
else
NS <= o_win;
end if;
when no_win =>
--result <= "11";
when others => NS <= idle;
end case;
end process;
end architecture;
library ieee;
entity x_o is
port (d_in : in std_logic_vector (1 downto 0);
clk, rst_n : in std_logic;
stts : out std_logic_vector (1 downto 0));
end entity;
architecture arch_x_o of x_o is
component FSM is
PS : in state;
NS : out state);
end component;
signal row_status : state := idle;
type matrix is array (0 to 2) of state;
signal mem : matrix := (others => idle); --memory reg for column check. every index will be a state by itself
signal temp : state := idle;
signal NS : state := idle;
signal i : integer := 0;
begin
temp <= mem (i); --why can't i just use mem (i) in the component?, for some reason i cant do that.
u1 : FSM port map (d_in, row_status, row_status);
u2: FSM port map (d_in, temp, NS );
-- if this was sequential I would insert NS into mem (i) and advance i for next check
-- if I use a process for that with d_in and clk in the sensitive list and advance i
-- for every change in d_in and rising_edge ill get the the component is been used twice
--befor i advance and after
-- i wonder if i can do all that outside a process since the component has a process in him
end architecture;
thanks in advance
