stely000
Hello,
I'm designing a lite MIPS that supports base addressing jumps, and some basic operation(including imm) like computing an address and writing/reading from that address etc.
For the clock signal a mono pulse generator is used and a BCD display to show different result.
this is the data path that i'm trying to implement.
Until now i've manage to implement this part:
My problem is the DataMemory(DMEM in code). I can't get it to work. I don't know why.
The code for the entire entity is this:
I think my problem is in this section:
All the components are tested and work properly. The signals res(the address) and rd2(the data) have the correct values.
When I try to read from DMEM to see if i write properly in DMEM the output(temp) is 0. This can be 2 things: 1) I don;t write correctly in DMEM. 2) I don't read correctly form DMEM. This might be because I haven't design the RAM DMEM properly.
The DMEM block shoud have 2 signals for memory write and memory read, an address(on 8 bits) write data(on 8 bits) and a read data(on 8 bits).
The warnings and INFO are here:
All Current Messages V 20. apr. 11:46:56 2012
Program All Current Messages - Errors, Warnings, and Infos New
xst WARNING Xst:646 - Signal <set<6:0>> is assigned but never used. This unconnected signal will be trimmed during the optimization process.
xst WARNING Xst:646 - Signal <ovf> is assigned but never used. This unconnected signal will be trimmed during the optimization process.
xst WARNING Xst:1781 - Signal <ROM> is used but never assigned. Tied to default value.
xst INFO Xst:2679 - Register <regWrite> in unit <test_env> has a constant value of 0 during circuit operation. The register is replaced by logic.
xst INFO Xst:1561 - "D:/CA/L1/ssd.vhd" line 63: Mux is complete : default of case is discarded
xst INFO Xst:3031 - HDL ADVISOR - The RAM <Mram_reg_file> will be implemented on LUTs either because you have described an asynchronous read or because of currently unsupported block RAM features. If you have described an asynchronous read, making it synchronous would allow you to take advantage of available block RAM resources, for optimized device usage and improved timings. Please refer to your documentation for coding guidelines.
xst INFO Xst:3031 - HDL ADVISOR - The RAM <Mram_reg_file_ren> will be implemented on LUTs either because you have described an asynchronous read or because of currently unsupported block RAM features. If you have described an asynchronous read, making it synchronous would allow you to take advantage of available block RAM resources, for optimized device usage and improved timings. Please refer to your documentation for coding guidelines.
xst INFO Xst:3040 - The RAM <Mram_DMEM> will be implemented as a BLOCK RAM, absorbing the following register(s):
map INFO LIT:243 - Logical network reg_file1/Mram_reg_file1/SPO has no load.
map INFO LIT:395 - The above info message is repeated 15 more times for the following (max. 5 shown): reg_file1/Mram_reg_file4/SPO, reg_file1/Mram_reg_file2/SPO, reg_file1/Mram_reg_file3/SPO, reg_file1/Mram_reg_file5/SPO, reg_file1/Mram_reg_file6/SPO To see the details of these info messages, please use the -detail switch.
map INFO MapLib:562 - No environment variables are currently set.
map INFO LIT:244 - All of the single ended outputs in this design are using slew rate limited output drivers. The delay on speed critical single ended outputs can be dramatically reduced by designating them as fast outputs.
par INFO Par:282 - No user timing constraints were detected or you have set the option to ignore timing constraints ("par -x"). Place and Route will run in "Performance Evaluation Mode" to automatically improve the performance of all internal clocks in this design. Because there are not defined timing requirements, a timing score will not be reported in the PAR report in this mode. The PAR timing summary will list the performance achieved for each clock. Note: For the fastest runtime, set the effort level to "std". For best performance, set the effort level to "high".
par INFO Timing:2761 - N/A entries in the Constraints List may indicate that the constraint is not analyzed due to the following: No paths covered by this constraint; Other constraints intersect with this constraint; or This constraint was disabled by a Path Tracing Control. Please run the Timespec Interaction Report (TSI) via command line (trce tsi) or Timing Analyzer GUI.
trce INFO Timing:2698 - No timing constraints found, doing default enumeration.
trce INFO Timing:2752 - To get complete path coverage, use the unconstrained paths option. All paths that are not constrained will be reported in the unconstrained paths section(s) of the report.
trce INFO Timing:3339 - The clock-to-out numbers in this timing report are based on a 50 Ohm transmission line loading model. For the details of this model, and for more information on accounting for different loading conditions, please see the device datasheet.
trce INFO Timing:3390 - This architecture does not support a default System Jitter value, please add SYSTEM_JITTER constraint to the UCF to modify the Clock Uncertainty calculation.
trce INFO Timing:3389 - This architecture does not support 'Discrete Jitter' and 'Phase Error' calculations, these terms will be zero in the Clock Uncertainty calculation. Please make appropriate modification to SYSTEM_JITTER to account for the unsupported Discrete Jitter and Phase Error.
----------------------ENTITY-----------------------------
entity test_env is
Port ( clk : in STD_LOGIC;
btn : in STD_LOGIC_VECTOR (3 downto 0);
sw : in STD_LOGIC_VECTOR (6 downto 0);
led : out STD_LOGIC_VECTOR (7 downto 0);
an : out STD_LOGIC_VECTOR (3 downto 0);
cat : out STD_LOGIC_VECTOR (6 downto 0);
dp : out STD_LOGIC);
end test_env;
---------------------END---------------------------------
architecture Behavioral of test_env is
----------------------MPG component-------------------
component mpg is
step : out STD_LOGIC_VECTOR (3 downto 0));
end component;
-------------------------END--------------------------
----------------------SSD component-------------------
component ssd is
Port ( d1 : in std_logic_vector(3 downto 0);
d2 : in std_logic_vector(3 downto 0);
d3 : in std_logic_vector(3 downto 0);
d4 : in std_logic_vector(3 downto 0);
anod : out STD_LOGIC_VECTOR (3 downto 0);
catod : out STD_LOGIC_VECTOR (6 downto 0);
clk : in STD_LOGIC);
end component;
-------------------REGISTER component-----------------
component reg_file is
port ( clk : in std_logic;
ra1 : in std_logic_vector (3 downto 0);
ra2 : in std_logic_vector (3 downto 0);
wa : in std_logic_vector (3 downto 0);
wd : in std_logic_vector (7 downto 0);
wen : in std_logic;
rd1 : out std_logic_vector (7 downto 0);
rd2 : out std_logic_vector (7 downto 0));
end component;
-------------------ALU component----------------------
component cascade_alu is
generic (
width : natural range 4 to 16 := 8
port(
a : in std_logic_vector(width - 1 downto 0);
b : in std_logic_vector(width - 1 downto 0);
c_ainv : in std_logic;
c_binv : in std_logic;
c_aluop : in std_logic_vector(3 downto 0);
c_ovf : out std_logic;
c_zero : out std_logic;
res : out std_logic_vector(width - 1 downto 0)
end component;
-----------------------SIGNALS------------------------
signal rcnt : std_logic_vector(7 downto 0);
type mem is array (0 to 2**8-1) of std_logic_vector (15 downto 0);
type ram_type is array (0 to 2**8-1) of std_logic_vector (7 downto 0);
signal pc_count: std_logic_vector(7 downto 0);
signal step : std_logic_vector(3 downto 0);
signal step_d : std_logic_vector(3 downto 0);
signal op : std_logic_vector (3 downto 0);
signal ra1 : std_logic_vector (3 downto 0);
signal ra2 : std_logic_vector (3 downto 0);
signal wa : std_logic_vector (3 downto 0);
signal wd : std_logic_vector (7 downto 0);
signal rd1 : std_logic_vector (7 downto 0);
signal rd2 : std_logic_vector (7 downto 0);
signal imm : std_logic_vector (7 downto 0);
signal disp : std_logic_vector(15 downto 0);
signal rom_d : std_logic_vector(15 downto 0);
-- control signals
signal regWrite : std_logic;
signal regWritei : std_logic;
--control signals for ALU--
--NOTE: caryy in nu trebuie, e aceeasi cu b_inv--
signal a_inv,b_inv,ovf,zero:std_logic;
signal res:std_logic_vector(7 downto 0);
--ALU src--
signal alu_src:std_logic;
signal data2:std_logic_vector(7 downto 0);
--RegDst--
signal RegDst: std_logic;
attribute equivalent_register_removal: string;
attribute equivalent_register_removal of rom_d : signal is "no";
-- DMEM --
signal memWrite:std_logic;
signal temp:std_logic_vector(7 downto 0);
signal DMEM : ram_type:=( x"44",
x"44",
x"44",
x"44",
x"44",
x"44",
x"44",
x"44",
others => x"11"
signal we:std_logic;
attribute equivalent_register_removal of temp : signal is "no";
signal ROM : mem := (
x"0005",
x"0019",
x"0024",
x"0035",
x"0049",
x"0054",
x"0005",
x"0015",
x"0025",
x"0035",
x"0046",
x"0056",
x"0036",
x"0046",
x"0056",
x"0066",
x"0076",
x"0086",
x"0096",
x"0006",
x"0017",
others => x"0000"
begin
mpg1: mpg
Port map (
clk => clk,
btn => btn,
step => step
ssd1: ssd
Port map (
d1 => disp(15 downto 12),
d2 => disp(11 downto 8),
d3 => disp (7 downto 4),
d4 => disp (3 downto 0),
anod => an,
catod => cat,
clk =>clk
ALU: cascade_alu
Port map (
a =>rd1,
b =>data2, --rd2 sau imm
c_ainv =>a_inv,
c_binv =>b_inv,
c_aluop =>op,
c_ovf =>ovf,
c_zero =>zero,
res =>res
process(clk)
begin
if rising_edge(clk) then
step_d <= step;
end if;
end process;
-- program counter
process(clk)
begin
if step_d(1) = '1' then
pc_count <= pc_count + 1;
end if;
end if;
end process;
-- temp counter for DMEM
process(clk)
begin
if (step_d(2) or step_d(3)) = '1' then
rcnt <= rcnt + 1;
end if;
end if;
end process;
-- rom
rom_d <= ROM(conv_integer(pc_count));
--DMEM--
process (clk,rcnt,rd2,we,memWrite)
begin
if we ='1' then
if memWrite = '1' then
DMEM(conv_integer(res)) <= rd2;
else
temp<= DMEM( conv_integer(rcnt));
end if;
end if;
end if;
end process;
led <= rcnt;
-- instruction decode
op <= rom_d(15 downto 12);
ra1 <= rom_d(11 downto 8);
ra2 <= rom_d(7 downto 4);
imm <= "0000" & rom_d(3 downto 0);
-- RegDst MUX --
process(rom_d(3 downto 0), imm,RegDst,wa,ra2,pc_count)
begin
if RegDst ='1' then
wa<=rom_d(3 downto 0);
else
wa<=ra2;
end if;
end process;
-- reg file
reg_file1: reg_file
Port map (
clk => clk,
ra1 => ra1,
ra2 => ra2,
wa => wa,
wd => wd,
wen => regWrite,
rd1 => rd1,
rd2 => rd2
-- control unit --
process(op,pc_count)
begin
case op is
-- add
when "0000" => regWritei <= '0';
-- addi
when "0001" => regWritei <= '0';
when others => regWritei <= '0';
end case;
end process;
--Alu src MUX--
process(alu_src,imm,rd2,pc_count)
begin
if alu_src ='1' then
data2<=imm;
elsif alu_src = '0' then
data2<=rd2;
end if;
end process;
process(clk)
begin
if step(1) = '1' then
regWrite <= regWritei;
else
regWrite <= '0';
end if;
end if;
end process;
-- To BCD --
process(sw,rom_d,rd1,rd2,imm,wd,pc_count,temp,res)
begin
case sw(1 downto 0) is
when "00" => disp <= rom_d;
when "01" => disp <= rd1 & rd2;
when "10" => disp <= "00000000"&res;--"0000"&ra1 &"0000"&ra2;
when others => disp <= "00000000"&temp;--x"00" & wd;
end case;
end process;
dp <= zero;
a_inv<=sw(2);
alu_src<=sw(3);
RegDst<=sw(4);
memWrite<=sw(5);
we<=sw(6);
b_inv<=step_d(0);
end Behavioral;
--DMEM--
begin
if we ='1' then
else
end if;
end if;
end if;
end process;
