Feb 22, 2005 #1 E eemkutay Member level 1 Joined Apr 12, 2004 Messages 40 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 250 Friends let's collect Component tester circuits and programs in the forum Added after 1 hours 25 minutes: **broken link removed** Dos program but good (analog and digital IC database) Added after 11 minutes: batronix IC database http://www.batronix.com/electronic/downloads/databook.shtml
Feb 23, 2005 #2 E eemkutay Member level 1 Joined Apr 12, 2004 Messages 40 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 250 everything Simple Component and Continuity Tester http://www.kpsec.freeuk.com/projects/simplet.htm Added after 11 minutes: Multi Wire Cable Tester **broken link removed** Added after 10 minutes: testers and everything about electronic http://www.commlinx.com.au/schematics.htm
Feb 24, 2005 #3 E eemkutay Member level 1 Joined Apr 12, 2004 Messages 40 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 250 IC tester(74xxx-40xxx) **broken link removed** Added after 17 minutes: https://www.tangentsoft.net/elec/opamp-tester.html for 8 pin opamps Added after 8 minutes: **broken link removed** old Hi-Lo programmer(dos program) + 74xx-40xx tester
