Component replacement
deJong
Member level 1
Member level 1
Hello Electronics Enthusiasts!
Please help find this component's replacement.
I want to replace this HIGH VOLTAGE FAST-SWITCHING NPN POWER TRANSISTOR with a component that is easy to find in the market.
Thanks in advance,
deJong
Where you are going to use? What is the actual operating voltage & current rating of the device in field.
this is used as a switching transistor in an SMPS unit. actual operating voltages around +-100-180V.
2N6676. I've seen some replacements but rating is too high. 2 times or more from its original rating is too high
