communication between two micrcontrollers
yonas abawary
Newbie level 3
NZ
Hi
i have got a project using two pic16f690 micro controller so i need some one
to help me how to connect between two micro controllers.
cheers:[/b]
You can communicate two microcontroller with the help of communication protocols.
Basically in almost all microcontroller is having inbuilt SPI (Serial Peripheral Interface) & I2C protocols.
So just check it out the communication protocols in your microcontroller.
Regards
Chanchal
thanks for your replay.
ya i have connected VDD to VDD and VSS to VSS and four LED's also to I/O PORTA RA0,RA1,RA2,RA3. each micro controller to each I/O PORTA. so can i connect the two PORTA's to each other?or just i leave the two PORTA's as it is?
regards
Hi Chanchal
thank you so much for your replay.it was very helpful so i appreciate that.
cheers
Try to read the data sheet from microcontroller for SPI protocols in Master & slave mode you will learn so many things.
Regards
Chanchal
Hi chanchal.chauhan
thank you so much i have read the data sheet that you have sugested yesterday and i have got exactly what i want.
cheers
