I wanted to establish a communication between 2 fpgas connected to the motherboard of a pc on 2 seperate pcie slots.
Can I send some packets from FPGA1 to FPGA2 without getting the cpu involved ?
Can anyone please share where can I fond the information / documents regarding the same.
If you're dealing with Xilinx 7 series, you can use an AXI bus PCI ip core. You can then have an controller in the fpga which has certain to certain inputs. Just wrap the axi wrapper with a fsm.
Thanks, Yes I am using xilinx ultrascale which have axi bus pci ip core.
Can you please help me understand "You can then have an controller in the fpga which has certain to certain inputs." this.
What I understood so far, is that I have to configure 1 pci IP as master in one fpga and 1 pci ip as slave in another fpga.
