kavkav
Junior Member level 1
- Joined
- Jan 6, 2011
- Messages
- 15
- Helped
- 1
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,441
I'm using IRF610 Mosfet
https://pdf1.alldatasheet.com/datashe...LD/IRF610.html
to build a common source amplifier. The mosfet is n-channel enhancement mode.
I have read everything I could find on mosfets, read my lectures and still I don't understand how to do this. This is the best schematic I could find but I have no idea how to choose my resistor values:
I would greatly appreciate if someone could could guide me through this because everything I've come across, uses formulas which require a "gm" value or "k" parameter or "W/L" parameter and non of these which I have. I can't even calculate my gain because it depends on what resistors I use.
SPECS:
Power Supply: 24 Volts DC
Signal Source: 1000Hz AC from function generator with 150 ohm internal resistance (can go from -5 to +5 volts in amplitude)
voltage Gain: voltage of signal should multiply by a factor of 3 (at least).
Current Gain: I don't know as long as power gain is significantly higher than signal source
V(th): 2 to 4 volts according to datasheet
Thanks.
SPECS:
Thanks.
