Can anyone highlight the common mode regulation circuit given in the picture is a negative feedback (always) or an occasional positive feedback?! I am bit confused with the case, if the common mode at the detector output is lower than the reference, then is this not acting as positive feedback?!
Thanks for your reply. But my question is if the common mode regulation is only through negative feedback or is this some other special arrangement?! Sorry, I am not clear with that yet.
It's classical negative feedback. Don't know where you see "occasional" positive feedback? Vcm is compared with 1.25V reference by differential amplifier. Three inverting stages in the signal path (M5, M10 ML) make overall negative feedback.
Feedback loop compensation, but parallel RC, not implemented as miller compensation. Selected to achieve sufficient loop phase margin. Notice that common mode output load capacitance creates another pole, thus lag-lead compensation used.
Wonderful. I think you mean the pole created by the (Bond + Pack) Cap and the termination resistance at the output?! Why do we choose the common mode input for this compensation?! Is this because this is the high impedance node here?! So with minimum cap I can get good phase margin?!
Biggest problem in working LVDS or HDMI near or above 1Gbps after smart EQ on the channel in my experience is CMRR from any interference. Adding CM shunt to Gnd capacitance on the balun (SMD CM choke). It can be host specific and sometime just putting my finger over the flat balun reduces the BER sparkles on the video in random locations with high data variations like image edges
