jimito13
Advanced Member level 1
I have designed a fully differential opamp.It's a folded cascode archtecture with gain boosters.Each module has it's own cmfb circuit.After adding the cmfb and after substistuting all ideal things of the schematic (dc voltages sources) with the respective biases from the biasing circuitry,i notice that my output node's common mode potential (output dc voltage) is about 80mv larger that the value that had initially(Vdd/2).Shouldn't be made the proper correction from the cmfb's?This means that my cmfbs don't work or it is another cause for this difference?I should say that cmfbs excibit 20dB of loop gain and above 90deg phase margin.
Thanks in advance for any helpful idea.
