Resistanceisfutile
Member level 4
I'm looking to build a common emitter amplifier (biased using voltage dividers). I am assuming I need to set the Q point so that the input wave does not shift my transistor into the active or cutoff region. I was just wondering a couple of things:
1. What information on the datasheet, will tell me the Q-point (or the different regions) of the transistor, are they the same for every transistor of different?
2. Once I have this information, do I alter the resistor values to suit it or do something else?
My amplifier circuit is based on the one found on this page:
https://www.electronics-tutorials.ws/amplifier/amp_2.html
