Madara
Newbie level 5
- Joined
- Jan 6, 2012
- Messages
- 8
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,335
I have combined USBasp from http://www.fischl.de/usbasp/ and AVRCDC 232 from **broken link removed** into a single atmega 8.
It has a jumper to select between USBasp and AVRCDC.All other pin configuraions like :UART Tx,Rx,CTS,RTS and USBasp SCK,MOSI,MISO.TGT_Reset,LED and slow sck pins are connected as it is. Only that the USB D+ is connected to PD2 and USB D- is connected to PD3 and the jumper to select CDC/USBasp is connected to PD4.
The code and hex file is available for download at **broken link removed**.
This is modified only for atmega8 12MHz crystal. For other mcu, further compiling for respective devices is required.
The PCB layout and PCB design will be uploaded later if possible.
