8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
| behavioral file:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
entity DCT_beh is
port (
Clk : in std_logic;
Start : in std_logic;
Din : in INTEGER;
Done : out std_logic;
Dout : out INTEGER
end DCT_beh;
architecture behavioral of DCT_beh is
begin
process
type RF is array ( 0 to 7, 0 to 7 ) of INTEGER;
variable i, j, k : INTEGER;
variable InBlock : RF;
variable COSBlock : RF;
variable TempBlock : RF;
variable OutBlock : RF;
variable A, B, P, Sum : INTEGER;
begin
COSBlock := (
( 125, 122, 115, 103, 88, 69, 47, 24 ),
( 125, 103, 47, -24, -88, -122, -115, -69 ),
( 125, 69, -47, -122, -88, 24, 115, 103 ),
( 125, 24, -115, -69, 88, 103, -47, -122 ),
( 125, -24, -115, 69, 88, -103, -47, 122 ),
( 125, -69, -47, 122, -88, -24, 115, -103 ),
( 125, -103, 47, 24, -88, 122, -115, 69 ),
( 125, -122, 115, -103, 88, -69, 47, -24 )
--Starting
wait until Start = '1';
Done <= '0';
--Read Input Data
for i in 0 to 7 loop
for j in 0 to 7 loop
wait until Clk = '1' and clk'event;
InBlock(i,j) := Din;
end loop;
end loop;
--TempBlock = COSBLOCK * InBlock
Sum := 0;
for k in 0 to 7 loop
A := COSBlock( i, k );
B := InBlock( k, j );
P := A * B;
Sum := Sum + P;
if( k = 7 ) then
TempBlock( i, j ) := Sum;
end if;
end loop;
end loop;
end loop;
--Finishing
wait until Clk = '1' and Clk'event;
Done <= '1';
--Output Data
Done <= '0';
Dout <= tempblock(i,j);
end loop;
end loop;
end process;
end behaviorall;
testbench file:
LIBRARY ieee;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--USE ieee.numeric_std.ALL;
ENTITY lab4b_tb IS
END lab4b_tb;
ARCHITECTURE behavior OF lab4b_tb IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT DCT_beh
PORT(
Clk : IN std_logic;
Start : IN std_logic;
Din : IN INTEGER;
Done : OUT std_logic;
Dout : OUT INTEGER
END COMPONENT;
--Inputs
signal Clk : std_logic := '0';
signal Start : std_logic := '0';
signal Din : INTEGER;
--Outputs
signal Done : std_logic;
signal Dout : INTEGER;
-- Clock period definitions
constant Clk_period : time := 10 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: DCT_beh PORT MAP (
Clk => Clk,
Start => Start,
Din => Din,
Done => Done,
Dout => Dout
-- Clock process definitions
Clk_process :process
begin
Clk <= '0';
wait for Clk_period/2;
Clk <= '1';
end process;
-- Stimulus process
stim_proc: process
variable i, j : INTEGER;
variable cnt : INTEGER;
begin
-- hold reset state for 100 ns.
wait for 100 ns;
start <= '1';
wait for clk_period;
start <= '0';
for cnt in 0 to 63 loop
wait until clk = '1' and clk'event;
din <= cnt;
end loop;
--wait for 100 ns;
--start <= '1';
--wait for clk_period;
--start <= '0';
--for i in 0 to 63 loop
-- wait for clk_period;
--if (i < 24) then
--din <= 255;
--elsif (i > 40) then
--din <= 255;
--else
--din <= 0;
--end if;
--end loop;
wait;
end process;
END; |
