Code not working in PIC
Murugesh_89
Full Member level 5
Full Member level 5
India
Below is the code for led glowing in pic16f876a micro controller ( pin RC0 ) through positive logic. But it is not working. What else should be done?
#include<16f876a.h>
#fuses HS,NODEBUG,PUT,NOWDT,PROTECT
#use delay(clock = 8M)
void main()
int i = 0;
delay_ms(2000);
set_tris_b(0b11111111);
set_tris_c(0b00100000);
output_high(PIN_C0);
while(1);
Are you using CCS c compiler???
LED blinking ...
HTML:
#include "16f876a.h"
#fuses HS
#use delay(clock = 8000000)            //  8MHZ crystal
void main()
   while(1)
      output_high(PIN_C0);         //   pin C0 goes output high
      delay_ms(1000);                //   delay  1000ms
      output_low(PIN_C0);           //   pin C0 goes output low
Hi duke,
ckt is below.
