Code from Arduino to be in MikroC
kail123
Hi Guys , I have below code from Arduino and need help to change it to MikroC . the reason of this just to see how is MikroC will be changed the Function code .. i am going to use 16f877 with Osc 10 Mhz , using any port setup no issue for me , i will modify it later on . The code is controlling the speed of DC Motor with one Button .
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
int switchPin = 8;
int MotorPin = 11;
boolean lastButton = LOW;
boolean currentButton = LOW;
int MotorSpeed = 0;
void setup()
  pinMode(switchPin, INPUT);
  pinMode(MotorPin, OUTPUT);
boolean debounce(boolean last)
  boolean current = digitalRead(switchPin);
  if (last != current)
    delay(5);
  return current;
void loop()
  currentButton = debounce(lastButton);
  if (lastButton == LOW && currentButton == HIGH)
    MotorSpeed = MotorSpeed + 61;
  lastButton = currentButton;
  if (MotorSpeed > 255) MotorSpeed = 0;
  analogWrite(MotorPin, MotorSpeed);
I can write the code for you but you have to give me the PIC circuit because I have to know which pin connects to which component like LED, Motor, etc...
