code for microcontroller to receive data from bluetooth
yanti amol
Member level 1
Indonesia-surabaya
any help for me
what the code for for microcontroller to receive data from bluetooth (using C )
There is no code to directly recieive the Bluetooth data. Check your circuit for the interface betrween Microcontroller and the Bluietooth receiver. This could be probably SPI, USB, I2C or a parallel bus. Accordingy your code neds to be written..
Receiving data from a Bluetooth device is no different from getting data on the microcontroller's UART from any other source like a PC, or another microcontroller, if you use a serial bluetooth module like this one **broken link removed**
Just connect its TX, Rx to your controller thru a Maxim level shifter, and you are ready to go.
Regards,
Anand Dhuru
