pkaras
Junior Member level 1
I want to test BT over long range (>1km). I am looking for a flexible 50 cm coax cable to connect transreceiver to antenna. RG316 seems to be the best fit. RG405 would be even better, but it is semi-rugged. Is there any flexible alternative to RG405 that is flexible, not very thick and has similar characteristics? If not, how would you rate RG316 cable - will it be good enough?
