kokokokokoko
Newbie level 2
Hi i have been trying to simulate a simple dipole fed by a coax cable but i have always failed to acomplish it due to numerous mistakes with coax. I have read and search like crazy for examples and someof them like pdf of patch fed by coax is specifying some of the options for exicutions that my v10 hfss does not have or ......
I was wondering if someone could create basic dipole fed by a coax that actually works in simulation.
Let's say each arm of dipole would be a tube 2" in diameter and 1/4 of a wavelength for 125MHZ in length
the coax cable would be connected between two tubes and length of cable would be 1 wavelength in cable not air.
if anyone has time and is willing to do it it would help a lot i need to simulate a much more complex structure but i think i could do it if i get this example for hfss.
thank you
thank you
