Yosmany325
Member level 3
Hello everyone. I'm new in this forum and maybe my question is not for this but I don't know where to ask for this. I have searched on internet regarding this but I haven't find something like I want.
Right now I'm trying to make a CNC machine, mainly for PCB drill/mill. My question is where I can find information related to spindle construction, I mean, DIY spindle construction.
If someone can answer the following question I will appreciate much his/her help. Thanks in advance.
The questions are:
Why is needed an spindle?
Why not connect the chuck to hold the drill bit directly to the motor shaft?
I'm planning to use an RC brushless DC motor (A2212/13T KV1000), for this motor:
Can it be operated with the rotor reversed? (See the attached picture)
I have seen some DIY spindles, they use atleast two ball bearings and a shaft. Can I use something similar in the following scheme?
Motor_Shaft [3.17mm] + Coupler [3.17 --> 3.17mm] + Shaft [3.17mm] + Chuck [with adapter for 3.17mm]
Thanks in advance for your help.
The questions are:
