CNC Problem-- Convert Step-Direction to servo direction.
Moof
Full Member level 2
Argentina
gertronik
Everybody knows that every CNC software controls Steper motors with pulse-direction instruccion.
Can someone give me an idea to convert pulse-direction instruccion to a Servo instruccion, like speed... position, etc?.
step direction to analog
Hello Moof,
I'll be not so sure that every CNC uses step motors. All real CNC machines I've seen use servos.
Could you please tell us what is your application?
What kind of CNC do you have?
Best regards!
dc servo pulse-direction input
OK, i have mach3 software... and now i want to convert the output of mach3 (for steper motors) to servo motors. Do you have any idea how can i do that?.
step/dir to analog converter
Hello Moof,
I think that the easiest way to do what you want is to get a servo driver with pulse and direction input.
I remember having worked with some servo driver from Allen Bradley that have analog voltage input and pulse direction input, but I can't remember now the part number.
Best regards!
step dir servo
The BEST selfmade Hardwarecontroller to make from Step/Dir to an real DC Servomotor
Uli`s Homepage:
The Proz
http://www.uhu-servo.de/
UHU Proz
http://www.pyromantiker.de/servo/UHUservo300.zip
Komplett PCB , Circuit usw.
Werner Startmann`s Online Analyzer:
The funktion from the PID in UHU:
http://www.uhu-servo.de/servo_de/PIDsimple.pdf
Liste of material
http://people.freenet.de/Mode1/UHU_Platine_Stuecklisten.xls
PCB
WIKI Site
Michael
