Nurahmad
Junior Member level 1
- Joined
- Apr 10, 2013
- Messages
- 16
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Kuala Lumpur
- Activity points
- 1,452
I want to simulate NMOS and PMOS noise behavior in 130nm technology with Mentor Graphics tool, parameters as below:
Vds=0.7V
Id=185uA
W/L=100/0.4 um
in order to get Id=185uA, Vgs has to be set around 0.36V. I put a AC voltage signal with offset 0.36V, magnitude default is 20mV.
The problem is, when I simulate AC noise behavior, my noise spectrum should be the ONOISE curve or the INOISE curve? (Should I take the drain net noise spectrum curve as my noise behavior of CMOS?)
From the images, the Onoise curve from drain net, while the Inoise from gate net.
Vds=0.7V
Id=185uA
W/L=100/0.4 um
