pal114525
Member level 5
Why do you worry this small distortion? Did you already monitor the bridge output voltages? Did you look at the transistor currents?1. How to remove the distortion from the Vosc output?
In a very idealized simulation circuit, bridge shoot-through may be avoided. But that's surely not a template for a real design.the two transistors will turn on and short the 12V supply, it appears the sim does not show this - it should...
But you would provide locking and deadtime generation in a real circuit.
Thanks for your valuable feedback.
Here, 10ohm resistor is the internal resistance of the coil.
Would you be kind to explain me the following point?
1. What the functionality of 10m ohm resistor in the circuit?
2. What are the purposes of using C1 and C2 along with the resistors in parallel.
Thanks & Regards.
