come512l
Newbie level 6
My Vhdl program seems to work when I remove the external clock, but when I add the clock to the RS 232 Reciever Code, It doesn't work anymore in the testbench.
I'm trying to make a UART application, PC to Spartan 3E, my PC (hyperterminal is set to 9600 baud rate) so I have to supply the clock RX DCE from the spartan 3 to match with the baud rate. (I have only done this on testbench on Xilinx) :roll:
My vhdl program is this: I have to send a word to a PC via hyper terminal and sent it to Spartan 3E via RS 232, then there will be an output on the LED depending on the set of WOrds that I sent. E.g BLINK --- output in LED is blinking
Clock code for RX (RS 232)
Here is what it looks like on the Top Module (Removing the Clock on THe RS232 and the CU makes the program seems to work)
entity ClockGen is
Port ( CLK_in : in STD_LOGIC;
CLK_out : out STD_LOGIC);
end ClockGen;
architecture Behavioral of ClockGen is
begin
process (CLK_in)
variable count : integer := 0;
variable clk : STD_LoGIC := '0';
begin
if falling_edge(CLK_in) then
count := count + 1;
if count = 2600 then
clk := not clk;
count := 0;
end if;
end if;
CLK_out <= clk;
end process;
end Behavioral;
