I´d use the returning clock (from CCD) directely as DFF clock.
This is a clean solution. (As long as you select the correct clock edge)
Then use additional DFF to synchronize the data from first DFF to your FPGA system clock.
--> Both clocks are synchronous, but phase shifted (delayed). Here - depending on delay time - you again need to select the correct clock edge.
This avoids the use of PLL.
(synchrounous serial SDR data transfer)
But for sure the PLL solution should be "clean", too.
Klaus
