Clock gating EFM32LG230 for PA15 PE15 pins blinking LED
yefj
Hello, i am trying to blink LED's which are connected to PA15 PE15 on my controller, as shown in the diagram bellow.
I have tried to look in the data sheet and reference manual for their memory locations and also for the clock gating address which enables the options for controlling PA15 PE15 , from the links bellow.
As shown in the tables bellow, i found that GPIO goes from 0X40007000 -0X40006000
but i coudnt find what addersess are relevant for PA15 PE15 and what clock gating addreses are relevant for enabling PA15 PE15.
please help.
Thanks.
https://www.silabs.com/documents/public/reference-manuals/EFM32LG-RM.pdf
https://www.silabs.com/documents/public/data-sheets/efm32lg-datasheet.pdf
You should be able to set port direction, port drive mode, and port output leves directly.
No need to go the bit_banding way.
Please tell us what compiler and IDE you use.
Show us your code.
Tell us how you verify proper programming and proper microcontroller function at all.
Hello Clause, I intend to use Simplisity studio with the code shown bellow.
If i did the port connection correctly for given my efm32lg230 controller.
How to do the blinking , i know that i should some how put a delay because if it blinks to fast then i wont able to see the blinking effect at all.
Thanks.
#include "em_device.h"
#include "em_cmu.h"
#include "em_gpio.h"
 #include "em_chip.h"
 #define LED_PORT_E    gpioPortE
 #define LED_PIN     15
#define LED_PORT_A    gpioPortA
 #define LED_PIN     15
int main(void)
    CHIP_Init();
     while(1);
Pseudo code:
Loop(
LED ON
DELAY_MS 500
LED OFF
DELAY_MS 500
I bet you can find similar code thousand times in the internet
Reactions: yefj
    yefj
