Clk multiplication in Spartan 2
Nikolai
Member level 3
clk dll in spartan 2
My spartan 2 kit has an external crystal of 4 Mhz. I need to generate 2 clocks of period 30 ns and 240 ns respectively.
Is this possible ? I guess DLL can perform only clock division, not multiplication.
mnimum dll frquency spartan2
That's correct, the Spartan-II doesn't have frequency synthesizers like newer FPGAs.
You'll need another external oscillator or synthesizer.
    Nikolai
U can make ur own clock from 4MHz but it will be the integral multiple of 4. U can use the posedge and negedge of the clock and double it and keep doing further until supported...... if it can solve ur problem then try it and for this i can even give u the code as well but in verilog
Hi aafaq, If you your quadrupling method works well, please show us how you do it!
I just realized that a DLL can do a 2X freq multiplication. And spartan 2 has 4 DLLs.
I wonder if all four can be used to achieve a 16X factor.
The Spartan-II DLL has a 2X feature, but its minimum input frequency is 25 MHz. See FCLKINLF in the data sheet.
Maybe you can replace your 4 MHz oscillator with something faster.
Cascading too many DLLs can cause malfunction due to jitter accumulation. Here's more info:
    Nikolai
Yes, i forgot the minimum freq requirement. Probably i'll try moving on to spartan 3 or get a faster crystal
