I did look for a tutorial on 4 layer layout (Eagle or otherwise) but couldn't find one.
Your requirements are quite normal and not something that needs blind vias. You would normally on use blind & buried vias when it is unavoidable - because it costs more. One example would be where you have a BGA on both sides of a board. You could not put a via completely through the board because it would hit the other BGA pads.
But, a normal layout of 4, 6 or maybe 8 layers would simple have vias that go straight through the board from top to bottom. You can also connect to them on any layers inbetween. So, while you might only want to connect from layer 1 to 2, the via also exists on layers 15 and 16. It does waste a bit of space but that usually isn't much of an issue.
I usually find more problems with vias between layers 1&16 hitting tracks on the inner layers when the layout is dense and components on both side.
So, use a simple 4 layer build and put normal vias from 1 to 16, and connect to them on the inner layers as required.
If you name you inner layers the same as you GND and VCC nets then when you add a via from a GND or VCC pad it will automatically connect to the inner layer. You will need to do a 'ratsnest' command to remove the unrouted net.
I hope I am being clear.
Keith
