sukhmani
Newbie level 5
After reading few documents about efficient power amplifiers, Class-E amplifier seems to suit the application that I need. So I have designed a circuit using MLX90130 to match with 50 ohm antenna which gives a power of 300mW. For the application, I require 2W, hence the need for power amplifier.
I have tried 2 variations :
One is not to include the shunt capacitance at the drain of IRF110 FET and at the load for harmonic suppression.
Other is to include both of them.
Also I came across one document where Class E RF Power Amplifier is simulated for 2W power at 13.56MHz for 50 ohm. But using those values too, I do not get 2W of power. This is the link to the circuit.
https://www.elektroniknet.de/automation/sonstiges/artikel/28383/3/
I am connecting the symmetric output after balun to the gate of this PA circuit. 50 ohm load should I use a resistor or just the SMA conctor and coax?
It would be grateful if I get some information about some moificatios I could make in the above circuit.
Thank you
Thank you
