Circuit to detect picoamperes current
To detect such a low current you really need something special ..
Here are a couple of publications for your consideration:
https://www.intronics.com/products/pdf/310.pdf
www.keithley.com/data?asset=6198
LEAKAGE RESISTANCE
In working with picoamp signals and/or impedance values in the range from 107 to 1011 ohms, attention to insulation and guarding techniques is extremely important. For example, a leakage resistance of 10ra ohms from the 15 volt power supply
to the negative input of the 31O will cause a 150fA error current which is 15 times greater than the 10fA bias current guaranteed for this amplifier.
107 means 10 to the power of 7 ..
1011 --> ten to the power of 11 ..
Regards,
IanP
SMUs can measure really small current change. Keithly have some good ones. SMU = sense measuring unit.
You can force voltage and see the current being drawn on your circuit.
LaTeX Commands Quick-Menu:
